Neo M8T Ublox Parameter and Pixhawk settings
Since a couple of days I have trouble to get my GPS unit running with the Pixhawk.
I've purchased the Neo M8T from CSG-Shop.
NEO-M8T Time & RAW Triple Band EMI protection +HMC5983 XXL version
Unfortunately CSG Shop doesnt really support their customers.
I hope someone of you is using the same unit and could help me.
When I connect the GPS unit to the pixhawk, the mission planner goes from Sat status 0 to 1, and the HDOP is 99.99.
I've left the powered drone more than half an hour outside but nothing changed.
I would really apreciate help!
Thank you so much!
Cheers
Michael
  • Hi Michael,
    I have the same GPS and it works very good with Pixhawk/APM !
    Did you change the configuration with u-center ? I can give you my configuration if you want !
    Nicolas
    • That would be awesome! Can you send it to me via email?
      Michaeltietze90@gmail.com
      Thank you so much for your help!!
      Cheers Michael
      • I give you my setup here (for multicopter, not plane), this could be used and improved by other people :
        U-center :
        NAV5
        Dynamic Model = 3 - Pedestrian
        PRT
        Target = 1 - UART1
        Protocol in = 0+1 - UBX+NMEA
        Protocol out = 0 - UBX
        Baudrate = 38400
        RATE
        Measurement Period = 200 ms
        Measurement Frequency = 5.00 Hz
        Mission Planner :
        GPS_TYPE = 2 (uBlox)
        Just a question, do you see the satellites with u-center ?
        Nicolas
