48 Flying Wing Kit designed for FPV flight from FlyThroughTheLens.com
The HairFire  delta wing platform is designed for experimental modelers entering into FPV This lightweight delta has a large payload bay that will accommodate a variety of sensor packages including our DIY 40mm Ball Turret Camera. This basic kit can be fitted in a pusher (with elevons trimmed) or a tractor configuration. We prefer the tractor configuration as it is considerably quieter and can be hand launched with a powerful motor without fear of shredding your fingertips. This airfame is over 700 sq. inches, has a pre-cut 132 inches ³ payload area and can carry up to a 2 lbs payload and still be under 4.4lbs. The “HairFire™ ” airframe comes in two levels of kits, the FPV Delta Wing Basic Kit, and the FPV Delta Wing HairFire™ Kit.
FPV Delta Wing Basic Kit $49
Included in the Kit:
· 48 inch EPP Wing Cores with Wing Shucks
· [8] G-10 Fibergalss Spars
· Pre-Cut 132 inches ³ Payload Area
· Magnetically Secured Hatch Cover
· Balsa Wing Trailing Edge
· Balsa Wing Tip Platess
· [2] Servo Control Horns
FPV Delta Wing HairFire™ Kit $99
· 48 inch Wing Cores with Wing Shucks
· [8] G-10 Fiberglass Spars
· [6] Balsa Stabilizer Fins
· Tractor Motor Mount (made to fit Rimfire.25 4240 1000 Brushless Outrunner or similar)
· [2] Nylon Motor Mount Bolts
http://www.youtube.com/watch?feature...&v=-jMXskhhw7E <-- Youtube video of the HairFire™ Airframe in flight.
Orca-Kote Wing Covering $16.99
The Orca-Kote™ system was designed for use with EPP. After many prior attempts to cover EPP with then available coverings we determined that we needed to develop our own system. The Orca-Kote™ Covering is a two layer system that combines the strength of fiberglass with the smoothness and moisture resistant properties of iron on films. The fiberglass layer bridges voids in EPP foam and produces a smooth surface requiring no filler. The heat shrinkable iron on surface film comes in a matte finish that accepts paint.
1 Roll of Orca-Kote Base material 26” x 72”
1 Roll of Orca-Kote Iron on Film 26” x 72”
Easy to follow instruction sheet
© 2015   Created by Chris Anderson.
