Just got finished assembling my new Delta Wing. It is a new kit from BEV RC. I have been looking for a good delta wing platform for doing so aerial AP (ortho maps). Most of the platforms that I have come across seem to have limited mounting space. Then BEV RC released their new X5 for FPV. I ordered it as soon as they were in stock. There is plenty of mounting space inside for APM and flight gear. I also picked up one of their nano cams, specs were pretty impressive for its size. The cam works well. Getting better image resolution than some of my larger cams.
I have never setup an APM on a delta wing, but anxious to do so. anyone know of any good resources for this? Wandering if anyone has any default settings for the funjet (which has been used with the APM before) that I can use as default settings for my X5, so as to shorten the tuning curve. I have been flying the skywalker for a few months now, and love it. The Skywalker parameter file was a little buggy, but we got it worked out. It has been an excellent platform for long duration aerial AP. I am hoping for the same with the X5, but it offers the advantage of being more portable. Any help appreciated:)
Cam specs:
| Sensor | Single chip 1/3 CMOS |
| Numbers of pixels NTSC | 656(H)×492(V);PAL:786(H)×576(V) |
| Image signal process | Digital Signal Processing System |
| Sensor dimensions | 4.75mm(H)×3.55mm(V) |
| Horizontal resolution | 520TV Lines |
| Scanning system | 2:1 Interlace |
| Sensitivity | 0.008Lux/F1.2 |
| Lens view & angle | 0.5mm F2.0 / 62 ° |
| S/N Ratio | 48dB |
| Video out | 1.0V p-p/75ohm |
| Size (L x W x H) | 9.5mm x 9.5mmx 12mm |
| Weight | 1g |
| Working current | 75mA |
| Power requirement | DC: 3.3V-6V |
| Operating temperature | - 10° C ~ +50°C ,less than 90% RH |
Tags:
Permalink Reply by Benjamin Mitchell on August 20, 2011 at 11:47am any thoughts on how to connect the APM in conjunction with the wing? Meaning the strange control surfaces.... I have seen a few people try it with varying success.
Thanks,
Ben
Permalink Reply by Todd Hill on August 22, 2011 at 1:01am I found the tutorial for the funjet setup in the wiki. All of the controls work well. My first flight wasn't so successful though. Too sensitive when I flipped to stabilize mode. Flipped back to manual, but didn't have time to pull up to miss a tree. Plane is fine. I recently loaded the Funjet parameters found in the download wiki. I plan on trying them tomorrow. I will post results this week.
Did you get to fly a successful flight with the X5 and the APM?
Permalink Reply by Todd Hill on October 27, 2011 at 7:48am Had three decent flights with it. Mounting the APM and proper balancing is an issue. It is very touchy on the controls, even after reducing rates. Been too busy with other projects lately to do further tuning. I have it hanging up right now in my shop. It beckons me everyday to take it back out. Hopefully soon I will be able to.
Permalink Reply by Joseph on May 22, 2012 at 5:49am Can you email me the latest param file on you x5. I just got one and I think that your progress ould be a great starting point for mine. Plus any install pictures would be great. Thanks for your help.
uavpilotjoe@me.com
Permalink Reply by Christiaan van Vollenstee on October 11, 2012 at 4:16am
Permalink Reply by Per Elofson on October 19, 2012 at 6:44am Hello Todd!
Is there any chance that I could get a copy of the Skywalker 1900 param file that you've got?
per.elofson[At]gmail.com
Best regards,
Per, Sweden
1283 members
676 members
4 members
8 members
Powered by
