DGPS RECEIVER AirStandard is designed specially for the high-precision flight of the UVAs. It is compatible with TI and T1-A to make the UVAs achieve the cm-level precise position. We're going to launch it at 2017 Cebit!
The internal board of DGPS RECEIVER AirStandard adopts GPS+BDS dual-system-five-frequency high dynamic calculating engine which supports the super long baseline E-RTK measurement. The frequencies received by the board include BDS B1/B2/B3 and GPS L1/L2. It supports GPS/BDS single system independent position and GPS+BDS joint system position, adapted to more severe and longer-distance position environment.
Main Parameter
Tracking Signal GPSL1C/AL1PL2P BDSB1IB2IB3I
First position time Cold start<50s Hot start<45s
Recapture Signal L1/B1 <1.5sfast<3sordinary
Position Precision
Single-point precision: 1.5m
Fixed solution precision: Horizontal 0.01m  Vertical 0.02m
Floating solution precision: 0.4m
RTK Performance
Initialization time <10sbaseline length <20km
Initialization credibility >99.99%
Data Rate 5Hz
Physical size and electrical characteristics
Voltage +5V±5%VDC
Power consumption 2.8w
Weight 95g
Size 112mm*52mm*17.5mm
Environmental indicators
Operating temperature -40 ~80
Storage temperature -55 ~95
Cebit: March 20-24, 2017
[url]http://www.cebit.de/en/[/url]
Deutsche Messe AG
MessegelAnde 1, Hannover, 30521
BoothH006 G54
Now it is GPS+GLOANASS+BDS trinal-system-five-frequency high dynamic calculating engine.
