Newbie Mission Planner question
I tried setting up a mission for my flying field, which is about 2 miles from my house.I set waypoint 1 for takeoff, then added 6 more, with the last one set as RTL.Waypoint 1 does not show on my screen. The screen does show 2 dashed lines which go to my house, which is listed as "HOME".Is that going to be a problem? I sure don't want it heading back to my house after that last waypoint!Thanks and sorry for the simpleton question.
  • The Home Position is where your copter is when it gets a GPS fix. THAT is where it will go with RTL.
    MP is really aggravating when you are trying to set up a mission at home, isn't it? It keeps jumping back to your actual home. I wish it would reset Home to the takeoff position in a mission while you are creating it.
    If you go into auto mode when you are away from where your mission is set up, though, it will try to fly to where the waypoints are.
