Hello all,
Probably not a new idea, but something I'm thinking of tackling. I want to build a RC plane capable of flying a preset course and taking pictures along the route. Then fly back home. All under the cover of darkness. I then want to take the pictures and be able to get GPS coordinates on them to be able to see where deer are bedded down. I need ideas for a good IR camera, large flying platform (I think I wanna do a gas engine), and a way to be able to search each picture with GPS coordinates. basically I wanna be able to pinpoint down to a GPS coordinate the bedding areas in my hunt club........
Any ideas?
Tags:
Permalink Reply by Luke Nyhof on January 29, 2012 at 6:39pm Hi All,
Just a quick side note, certain late model Mercedes Benz vehicles are now fitted with a FLIR camera system, perhaps a reccy of you local wreckers might prove beneficial, these cameras use a standard video out and, if need be, can have an OSD integrated with the camera feed, if using resolvers/encosers on stepper motors to read out the pitch and yaw of the camera along with a decent GPS and a laser rangefinder (eg: Bosch Blue series make a handheld version) you could easily make a system which could geotag and rangefind any "hot-body" for hunting purposes...
Also the FLIR camera is lightish, and can be easily mounted on a camera gimbal.
We use these systems at my work for certain special projects.
Just my 2c.
Cheers,
Luke
Permalink Reply by Eraser on January 29, 2012 at 8:33pm Using the FLIR EVSX?
I found it kinda heavy for a quad, but they work great on HEXA's and I power them off the same 5 volt dc converter I use for everything else.
Permalink Reply by Luke Nyhof on January 30, 2012 at 10:20pm That's the one, quite small and relatively light weight and no need for heavy cooling for the thermal sensor.
Permalink Reply by Luke Nyhof on February 2, 2012 at 9:57pm Actually I stand corrected, the model that I have been using is the FLIR PathfindIR, it's about 400g and fits in your hand, runs off 12vdc at approx 2-6W.
See: http://www.flir.com/uploadedFiles/UserManual_PathFindIR.pdf
Permalink Reply by Luke Nyhof on February 5, 2012 at 9:30pm That's the one, doubtful there would be much difference between the models. How do you find the image clarity due to the vibration induced by the frame of the hexa?
Permalink Reply by Eraser on February 5, 2012 at 9:47pm Not too much of a problem, I mounted it with Vibration dampeners, and built the standoff from UHM Polyethylene, so I think that helped... I am also using a video encoder that helps smooth the image a little..
Eraser
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.83 members
24 members
682 members
1289 members
182 members
Powered by
