I've just upgraded to Arduplane 2.5 using the APM planner 1.2 onto my APM 1.0. All seemed fine, but when I move the switch towards the pin headers, to start flight mode, and reset, I just get a sold green LED, nothing else lights up (not the regular alternating green and red).
I can't connect to it either over USB. If I switch back to terminal mode (away from headers), I see Arduplane 2.5 is loaded and I can run setup, etc.
Please help? Board / switch broken?
[EDIT] It does work when I hold down the reset button for a second and release, then it initialises as per normal, however I can't do this every time before flight because the APM is well tucked away in the fuse.
I'll appreciate any ideas why a reset is required before it initialises!
Tags:
Permalink Reply by Hein du Plessis on August 2, 2012 at 4:12am I am quite embarrassed. After not flying for 2 weeks I got confused about which way to switch for flight mode. Interestingly the documentation does not really mention it any more? Please ignore...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
130 members
315 members
185 members
51 members
Powered by
