Tags:
Permalink Reply by Paul Thompson on December 3, 2010 at 9:58pm
Permalink Reply by Dean Lamborn on December 4, 2010 at 10:26am
Yes if you have IsAM activated and OUT4-7 pins in use on ArduUser.h file, camera servoes won't work. So either uncomment IsAM and/or change ArduUser.h
/* AM PIN Definitions */
/* Will be moved in future to AN extension ports */
/* due need to have PWM pins free for sonars and servos */
#define FR_LED 3 // Mega PE4 pin, OUT7
#define RE_LED 2 // Mega PE5 pin, OUT6
#define RI_LED 7 // Mega PH4 pin, OUT5
#define LE_LED 8 // Mega PH5 pin, OUT4
#define FR_LED AN12 // Mega PE4 pin, OUT7
#define RE_LED AN14 // Mega PE5 pin, OUT6
#define RI_LED AN10 // Mega PH4 pin, OUT5
#define LE_LED AN8 // Mega PH5 pin, OUT4
to be:
(yes i know later ones have wrong pin marking on their comments)
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
207 members
24 members
52 members
719 members
Powered by
