No waypoints visable when playing back .tlog
In the past when I played back a .tlog to review my flights I could see all the waypoints that the APM is navigating to in auto mode. However it appears that they are no longer there. I see the plane flying on the Flight Data screen map, and I see the blue snail trail it is leaving behind, but the flightplan no longer appears on the map. I am using the latest 1.2.78.
Is there something I need to do to toggle this option on?
  • In the past I noted u have to "play" until WPs show up. Don't drag the cursor until they show up. I also noted that if u play too fast until WPs show they will not appear.
  • Admin
    @iskess,
    Have you been reading the waypoints stored in the APM into the Flight Planner window prior to going to the auto mode? I believe that you need to do that for the waypoints to be captured in the tlog of a particular mission.
    TCIII ArduRover2 Developer
