You know what also might be interesting, is the use of a Sony HDR-TD10 3D camera and the Sony HMZT1 Head Mounted 3D display, but I am sure that would all just compound the transmission issues.
I have been working on a solution that will do this. It is pretty expensive. I have a MicroHard VIP5800 radio that is essentially an ethernet bridge with a high speed serial sideband. I am taking HDMI video output, doing H264 compression and then sending it via the radio down to a ground station. The radios are about $800 for each end, but I picked them BOTH up from a guy for $350 along with some wiring and supporting hardware. Once I get it up and running I will post results, I am still waiting on some of the hardware. I'm curious why one might want to stream the HD video? I am only doing it because on my camera when you connect the control cable you lose the composite output, and only have HDMI to work with (Bad Sony...Bad!)
HD video requires a lot of bandwidth and processing power to get it down from the aircraft and displayed with a latency that is still usable to fly by. I haven't yet seen solutions for this but people are working on it...
Some professional solutions for streaming full HD wirelessly exist, but I doubt you are looking to spend thousands just for that. Also having some latency isn't an issue when the purpose is to just get the footage, not to fly by the feed. The hobbyists will get there too though, eventually...
Here is a video of the system:
https://www.youtube.com/watch?v=RdHIohydwYE
http://www.4stateuav.com/product/long-range-hd-fpv/
This does HD
How about the Gopro. I have been reading it can record and stream at the same time. I assume its a reduced resolution that is streamed?
