One Motor Not Spooling Like the Others
I am hoping someone is able to help me as all other forums and searching hasn't yet.My Equipment:DYS 2300KV Motors, Lumenier 20A ESC's, Naze32 Fun FCB, Flysky FS-i6.My Issue: I flashed the FCB with the latest firmware through Cleanflight. I calibrate the accelerometer and when I attempt a test hover, motor 3 doesn't spin like the others. If I apply power slowly #3 won't spin at all. If apply power more aggressively it will spool up. If I get it to spin up and then park the throttle at 50% it will slowly spool down to 0.If I plug another ESC/Motor into the pins for #3 on the FCB, the issue stays with the pins for #3 and doesn't follow the ESC/Motor. This leads me to believe the issue is with the boards or software and not the motor #3 hardware.When in Cleanflight all the motors start and stop in perfect syc.I have tried a few other troubleshooting ideas but I don't want to rule anything out. Any help would be greatly appreciated. Thanks in advance!
