I want to be able to us my USB Joystick as a Gimbal controller.
Plan:
Use a Logitech USB joystick connected to my GSC Computer. Use the Mission planner to program it to move the pan and tilt of the gimbal via my xBee Pro telemetry link. I do not want to have the control of my camera linked to my R/C transmitter at all. The R/C transmitter is only for flying the plan only.
How would one do this. I plan to utilize servo out put 5-6 for the pan and tilt.
Any insight in how to do this would be great.
Tags:
Permalink Reply by Mike M on March 19, 2012 at 9:02pm Technically, it's pretty simple. You need to read input from the joystick (there are numerous examples on the Internet of interfacing to a joystick with .Net) and then send output to the XBee (a simple UART over USB). The work, on your part, will be to modify Mission Planner and APM firmware to support. You might want to proof-of-concept as a stand alone app and a separate Arduino board.
-Mike
Permalink Reply by Joseph on March 21, 2012 at 6:23am Can't this just get mapped via Mission Planner? You can already control flight surfaces via joystick. I just don't know what axis in mission planner will move servo outputs 5-6.
I really didn't want to re write software here. I am not a programmer. I am just a pilot...
Permalink Reply by Samo on April 7, 2012 at 4:14pm I want to know this also, I already have auto-takeoff and land procedure working 100%, i don't use RC anymore.
I know there is a way, it is enabled in APM mission planner, but only for arducopter code. It would be nice to have it in arduplane also. servo PAN, servo TILT, servo RETRACT. Retract could be initiated by APM mission planner and not joystick.
You could then also autohide/show sensor in specific altitudes.
Permalink Reply by Tommy Larsen on April 7, 2013 at 5:41am Hi
I have the same plan so i would like to know this also :-)
Tommy
1277 members
51 members
179 members
57 members
Powered by
