Tags:
Permalink Reply by Michael Pursifull on September 20, 2011 at 4:39pm I've done a blog post several months ago on this.
http://www.diydrones.com/profiles/blogs/quad-position-hold-with-mou...
Here are two decent papers I've read on the subject:
https://code.google.com/p/arducopter/wiki/AC2_OptFlow
http://www.mecatronica.eesc.usp.br/wiki/upload/0/0a/2006_Thesis_Rem...
The trick is that you need to compensate for the roll/pitch and also the values returning from the sensor will depend upon your altitude. If you're high up, you'll see less movement, if you're very close to the ground, you'll see more.
Permalink Reply by kuxz on September 20, 2011 at 9:24pm Currently I am using the mouse sensor from Sparkfun. I have found that the code from your blog and the arducopter site cannot be found. The sensor used in the arducopter site is different from the one that I am currently using, so is the code useful for my sensor?
Kuxz,
ok, so yes, we recently moved to git and that branch apparently got blasted because it wasn't very active. In terms of the math that's required to compensate for the roll/pitch you can find it in the optical flow library here. In paritcular look at the update_position function.
Sadly this library won't work for the sparkfun sensor because it's designed for the ADNS3080 while the Sparkfun one is the (less advanced sorry!) ADNS2620. By the way - the link you've posted for the sensor is the simple breakout board. Really you probably should have purchased the evaluation board. The big difference is that the evaluation board includes a Atmel 328 which makes talking to the sensor a lot easier because the ADNS2620 is not using a pure I2C. So for example you couldn't easily connect up the board you've purhcased to the APM and still use a magnetometer!
-Randy
Randy, is the Optflow mixed in now? What's the best way to test it?
Need a sensor first right?! Working on it!
I was one of the lucky ones to get an early board. =)
Permalink Reply by kuxz on September 21, 2011 at 8:11am I have tested the library provided on the sparkfun product page. I face problem reading the value from the X and Y coordinate of the mouse sensor. The only value that I read from the serial terminal of X and Y is purely FF. And I try moving the sensor around and the value remain the same. I am using Ardupilot board and have connected the data pin from the Mouse sensor to analog pin 4 and clock pin to analog pin 5. Anyone manage to read the X and Y coordinate using the provided library?
I used the sparkfun library but found a bug in the pins they had specified for communicating with the mouse. after i fixed that it worked ok ( but i was using the evaluation board with the 328 on it not the breakout board).
Only FF returning could mean that you have a wiring problem. maybe the pull up resistors on the set-up are too strong and the sensor doesn't have the strength to pull them down to zero. Just a guess.
Permalink Reply by estebanflyer on February 19, 2012 at 10:09am Hi Randy, I have tested my optical flow sensor and it's working great, and now I'm looking forward to connect it to the APM. There is 5 files with code on the 'downloads' page in the instructions, 2 of them are file extension 'h' and two are 'cpp'. which ones should I add to the Arducopter library? (I'm kind of lost when it comes to Arduino IDE, but I will give it a shot)
thx!
Permalink Reply by Ellison Chan on October 10, 2011 at 10:41am So, I looked at the AP2 code, and looks like support for optical flow sensor (ADNS3080) is in the code. Optical flow position is being blended with gps. Is it safe to enable it and how well does it work right now? What kind of range can the optical flow sensor work at, and what other conditions can I look out for?
Looks like Avnet has the ADNS3080 in stock pretty cheap @ $2.90 each, but shipping is $22, which is not too bad compared other sensors. Maybe if enough people are interested, we can do a group buy to reduce the unit cost.
Is it worthwhile to get the sensor at this point? Is there a tutorial for integrating this? Can it share the same I2C as the magnetometer.
Sorry for all the questions.
Permalink Reply by Ellison Chan on October 10, 2011 at 11:50am Sorry I see it's SPI and not I2C.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
24 members
184 members
87 members
682 members
Powered by
