I was just wondering if the Remzibi has been updated at all to work with APM2.0. I was previously trying to get a minimOSD, but those are out of stock at the moment. Also if anyone knows how the rangevideo OSD works with the APM2.0 too that would be good to know as I have access to a used one of those.
Thanks!
Nate
Tags:
Permalink Reply by Dan Ho on May 31, 2012 at 1:52pm Hey James,
Where can one find the s/w details in order to create the mavlink packet to do this? I don't yet know much of anything about mavlink. Turning off overlays wouldn't already be a standard cmd, right? You would have to know how to address the port that the osd is connected to and then look up the MAX7456 info to see what data to send it and then get the info that tells you how to format the mavlink cmd in order to get the bits into the 7456 in the right order. Is that the process?
Permalink Reply by Nate C on May 28, 2012 at 9:00am Awesome! Thanks for the quick response, I'll order that ASAP.
Permalink Reply by Gábor Zoltán on June 4, 2012 at 8:55am Hi,
What is new in MinimOSD 1.9 (MAVLink 1.0) ?
Just came out. No version change, just this "(MAVLink 1.0)"...
No description also. I mean i have not found any...
As far as I know, the only difference is that it supports MAVLink 1.0 (rather than 0.9). All of the Ardu* projects are moving to MAVLink 1.0 this week.
Permalink Reply by Gábor Zoltán on June 4, 2012 at 9:54am Ahaaa!
Thank you Chris!
What is the advantage of mavlink 1?
Where can i read more about it? :)
Permalink Reply by Gábor Zoltán on June 25, 2012 at 3:55am I can't find up to date source.
I had to go back to arduplane 2.34 because i was not able to use Minimosd.... :(
Please give us the newest code!
Permalink Reply by Gábor Zoltán on June 26, 2012 at 1:00am Thank you Chris,
I knew about the hex file, but i need the source to be able to put my code in, like, airspeed, relative altitude, battery percentage, etc.
Permalink Reply by Gábor Zoltán on July 10, 2012 at 1:55am Ok i did find it.
Here is the code with extra functions like, airspeed, home alt, battery remaining, etc.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.12 members
1298 members
249 members
183 members
693 members
Powered by
