Hey all,
right now I'm builing a UAV using thermopile sensors for stability.  Now I have an xy sensor and a z sensor both from FMA.
XY sensor:
z sensor:
Now I'm quite certain that the z sensor I'm using is a different type, but I feel I could adjust the gain to get the right values, the issue is that the z sensor output doesn't change.  No matter which way I turn it outside it reads about 250 to 350 on an 8 bit ADC (vals from 0 to 1024 with 1024 being 5V).  The xy sensors seem to work fine, but I'm not sure what's up with the z sensor.  I've got the red wire to 5V the black wire to gnd and the white wire directly to the ADC line.
I'm not sure if I wired this incorrectly, or this is a different sensor than I'm thinking, but any ideas would be appreciated.
Thanks,
Strix
Tags: Copilot, FMA, sensor, thermopile, vertical, z
I don't think that Z will work. I think it's a digital output.
Oh, I see, do you have any idea what the format is?
No i don't. do you have scope or logic analyzer?
http://www.sparkfun.com/commerce/product_info.php?products_id=8938
I've got a scope, but signal analysis isn't exactly my strong point. Thanks for the heads up on digital output though, and I'll keep trying to figure this one out.
