Hi everyone,
I've written a patch for APM that allows for the autopilot/IMU shield to be placed in any arbitrary orientation relative to the airframe. The patch (based on current trunk code) basically contains the code to add Euler angle offsets to the angles produced by the DCM code, along with a menu utility that automatically calculates the roll and pitch offsets, based on the gravity vector. A more detailed description of the patch is below (the patches, one for library code and one for the main APM code, are attached). As far as I can tell, this functionality is not currently present in APM or ACM.
I would like to have this patch reviewed for possible inclusion into the APM project but I'm unsure of the standard procedure to get in contact with a developer (I apologize if I missed any obvious instructions). I figured either this forum is an acceptable channel or someone would be able to point me in the right direction.
Any feedback on the patch code and/or underlying methods would also be appreciated.
Thanks,
Tim
--- Summary ---
IMU Arbitrary Orientation
This allows the IMU (and autopilot, if attached) to be placed in any convenient orientation relative to the airframe, especially to enable the autopilot to fit in smaller airframes.
Currently, the IMU assumes it is completely level (roll = pitch = 0 relative to earth) on startup in order to calculate the bias of the accelerometers. If the pitch or roll is actually non-zero, the recorded bias will be incorrect. For larger values of pitch and roll, the incorrect bias values will effectively decouple the accelerometer and gyro axes so that, under static conditions, the orientation of the aircraft will seem correct (due to the correction of the accelerometers) but, during rotation transients, the estimated orientation of the aircraft from the IMU will be incorrect (e.g. a yaw will produce both roll and yaw changes from the IMU).
In order to allow arbitrary IMU orientation, the constant roll, pitch, and yaw offsets of the aircraft relative to the IMU are calculated and added to each calculation of the Euler angles calculated by the DCM code. These angle offsets are hardcoded via constants in the configuration file. The accelerometer offset calibration is removed from ground startup (the gyro offset calibration is unchanged) and added to the Setup menu for manual setting.
A utility has been added to the Test menu ("orient") that determines the IMU orientation offset by comparing the measured gravity unit vector to the z-axis unit vector and requires the airframe to be in the desired position for airframe roll = pitch = 0. The calculated values can then be copied into the airframe configuration. This gravity-vector approach does not allow for the automatic computation of the relative yaw offset and, if the relative pitch offset is +/-90 degrees (i.e. the front of the IMU is pointing directly upwards or downwards), relative roll offset is unable to be calculated.
The accelerometer offset calibration menu option in the Setup menu ("accel") calls for the IMU to be placed on a flat surface so that roll = pitch = 0 relative to earth and runs the IMU::accel_init() function calculate and store accelerometer offsets. This behavior is the same as the original code, although, if IMU arbitrary orientation is enabled, this offset calculation is no longer run automatically on a ground start.
By default, the IMU arbitrary orientation behavior is disabled and the currently existing code (including startup accelerometer bias calibration) is executed. IMU arbitrary orientation behavior can be enabled by adding the following line to the airframe configuration file:
#define IMU_ARBITRARY_ORIENTATION ENABLED
Other constants related to IMU arbitrary orientation behavior:
RELATIVE_IMU_ROLL // Angle between roll axis of IMU and airframe (relative to IMU)
RELATIVE_IMU_PITCH // " " pitch " "
RELATIVE_IMU_YAW // " " yaw " "
An intended use example is as follows:
1) Enable IMU arbitrary orientation by setting "#define IMU_ARBITRARY_ORIENTATION ENABLED" in the configuration file.
2) IMU is placed on a level surface so that roll = pitch = 0 relative to earth.
3) The "accel" utility from the Setup menu is run to calibrate accelerometer offsets (EEPROM is automatically updated).
4) IMU is place in desired orientation on aircraft.
5) Aircraft is held steady at the desired airframe roll = pitch = 0 orientation.
6) The "orient" utility from the Test menu is run.
7) The offset values are copied and pasted into the definitions of the desired configuration constants (i.e. RELATIVE_IMU_ROLL, RELATIVE_IMU_PITCH, RELATIVE_IMU_YAW). Any angles that could not be automatically calculated should be manually determined.
8) Set the slider switch back to flight mode and upload the new autopilot firmware. The IMU should be correctly reporting the aircraft's orientation; check to ensure valid behavior.
Great!!!
Your scheme will only work for certain orientations - for any orientation where the z axis is rotated this scheme will compromise the DCM drift correction algorithms.  That is to say if you want to mount the board so that the I/O pins are in the front instead of the back this will be OK, but if you want to mount it so that the components face the side instead of up, the drift correction will not work correctly.
Doug, thanks for the comments, they are much appreciated.
I'm not sure I understand how the DCM drift corrections are affected at all by the scheme. The way I look at it, ignoring the patch, if the IMU were placed upside-down in an airframe and turned on (with accelerometer bias calibration removed), the IMU should show itself upside-down. If the IMU were then arbitrarily rotated, the IMU should properly show these rotations and the final orientation (i.e. its normal behavior). So, if I placed the IMU upside-down in an aircraft and I wanted it's orientation to be displayed right-side-up on a flight display, I would e.g. take the orientation reported by the IMU, offset the roll by 180deg, and then display this orientation. The patch basically does this: it adds a static offset to the angles, but only to the reported values (the DCM is untouched). (I don't believe these offsetted angles are fed back into the DCM or IMU anywhere; if so then my patch probably doesn't work as expected.)
I apologize if I've just completely missed your point...it's been a long day.
Still, would a better approach be to apply the orientation offsets at a lower level (assuming it wouldn't muck up the drift correction)? For example, a secondary, static DCM could be created from the relative angle offsets and this DCM could be applied to the raw accelerometer and gyro vectors. It seems, using this approach, the accelerometer offset calibration could be left in during ground start.
Thanks,
Tim
I've tested the patch a bit more with my current setup (the IMU is pitched down ~35 degrees with ~1 degree roll and 0 yaw) and correction algorithm still seems to function properly, even when twisted and shaken about pretty violently (with gyros saturating). I had disconnected the magnetometer during these informal tests and was able to quite plainly see yaw drift of >20 degrees. Still, this is not proof that the patch works in all orientations (although other setups were initially tested that were different from the setup described above) so I appreciate any specific concerns. (Doug, if this does not alleviate your concerns, can you please give me more specifics?)
Also, I've implemented a proof-of-concept version of the patch using a secondary, static DCM to apply the orientation offsets. This method allows for the use of ground/cold start accelerometer bias calibration. Otherwise, it seems to behave as the original patch. I can clean this code up and integrate it a bit better with the current code base if there is any real potential for getting such a patch accepted at some point in the future.
Please let me know your thoughts.
Thanks,
Tim
Hi Tim,
The approach you are taking is too simplistic.  It would be an acceptable solution if you wanted to mount the IMU say 20 or 35 degees off the normal orientation, but will mess things up for many of the possible 90 degree rotations.  The roll/pitch and yaw drift are corrected independantly using two separate reference vectors.  If you rotate the IMU into a position where one of the reference vectors has little or no orthogonal component with the axis/axes you are trying to correct, then you have effectively suppressed the drift correction for that axis.  It would be OK if you wanted to mount the IMU components up and with the gps connector to the right side for example, but would mess things up if you wanted to mount the IMU on its side.  Similarly, you recognize the euler angle singularity at pitch=90, but handle it just as a "can't do it" case.  Using a rotation matrix there is no singularity and it can be done, but it requires either for the rotation to be implemented within the IMU object or significant rework to the drift correction algorithm in DCM.
Orientation changes where you keep the components up but rotate the IMU in yaw are easy - just use an offset approach like you have done.  Orientation changes which only shift the z axis a small amount can also be done with an offset approach, but the further the z axis is moved from vertical the more the roll/pitch drift correction will be compromised.  Orientation changes with significant rotation of the z axis towards the horizontal plane require a better approach.
This is a good item for the to do list, but due to the critical nature of the DCM and IMU libraries, not something that will be implemented without thorough testing.  I think the cleanest implementation would be to apply a rotation matrix to rotate the accelerometer and gyro vectors in the IMU object.
Doug,
Thanks for the detailed response! Your explanation is extremely helpful.
To make sure I completely understand your post and why the DCM method behaves differently, please correct my current understanding where needed:
Ignoring the yaw case completely, in cases where the gravity vector is close to parallel with the roll or pitch axis, the drift cancellation loses its effectiveness. For example, at 90deg pitch, roll cannot be determined from accelerometer readings and cannot therefore be corrected when the IMU is in this position. In the current trunk code, this loss in effective drift cancellation also occurs at certain orientations in flight (e.g. the pitch of the aircraft is 90deg). The static DCM approach (applied to the raw IMU vectors) actually re-orients the axes at the raw IMU level so that drift correction when arbitrary orientation is in use behaves as in the current trunk code (e.g. for the case where the IMU is at 90deg relative to the airframe, drift correction will behave normally when the airframe pitch is at 0deg but will lose effectiveness as the airframe approaches 90deg).
I completely agree that code modifying such a critical portion of the autopilot should not just be thrown into a release without thorough testing. My hope is that I am able to submit a patch that addresses the feature (in some form or another) into a publicly available APM branch so others, in addition to me, can test the feature over time until it is deemed safe enough to include in the main APM trunk.
I'll clean up the DCM (applied to raw IMU vectors) version of the code and post it here for further comments.
Thanks again,
Tim
A patch that applies a DCM at the IMU level is attached. The DCM is applied to the raw accelerometer readings with bias subtracted and to the temperature corrected gyro readings.
During gyro initialization in the base code, the raw gyro values are read 200 times (and seemingly not used) before going through the offset calibration process. At the corresponding position in the accelerometer initialization code, the accel values are stored as the initial offset values. I'm not sure if there is a reason for this gyro code but I attempted to keep this behavior the same in the patch.
The actual function creating the DCM from Euler angles is in the AP_DCM class. I figured this made more sense than having it internal to the IMU class as the DCM applied to the IMU may also have to be applied to other sensors (e.g. a compass that's soldered to the IMU shield).
The test/setup menu usage for initially determining roll/pitch hasn't changed much from the original patch and still seems a bit clumsy.
Any feedback is appreciated.
Thanks,
Tim
