Hi.
When setting up APM on the ground, on Flight Data tab of the software, pitch is going up and down continously, if I switch to Stabilized mode, elevator replies to this situation, moves up and down.
This occurs ONLY when the uBlox GPS is connected.
If I remove GPS, it is steady (both the screen and elevator), only moves when I move the plane.
Is it normal?
Regards.
how are you powering the apm?
Permalink Reply by Derin Hakan Karakurt on May 8, 2012 at 3:48am with usb cable and lipo at the same time to power rc system and the motor.
sounds like you are having power issues. the ublox causing voltage sag on the apm
Permalink Reply by Derin Hakan Karakurt on May 8, 2012 at 4:07am thank you for reply.
what should I do then if you know?
Best regards..
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.186 members
1298 members
24 members
51 members
51 members
Powered by
