Pixhawk and SBEC 5.6V output
Hey guys,
I am powering my Pixhawk with the Power Module, but my plane uses a SBEC with 5.66V output for my 4 micro servos. I read that if I plug my SBEC to the servo rail in the pixhawk it acts a power backup, but I read that it mustn't be higher than 5.7V, because it can cause a Pixhawk reboot. So I'm very close to the limit. My question is: if my Pixhawk is using the Power Module, do I have to take care about my SBEC output voltage? If my Pixhawk is using the Power Module, could it be rebooted for a 5.7 SBEC voltage?
How can I do to avoid connecting my SBEC into the servo rail but not power the pixhawk?
Thanks in advance,
Marcus
  • https://pixhawk.org/modules/pixhawk
    "Servo rail input (4.8V to 5.4V) UP TO 10V FOR MANUAL OVERRIDE, BUT AUTOPILOT PART WILL BE UNPOWERED ABOVE 5.7V IF POWER MODULE INPUT IS NOT PRESENT"
    Hugues said:
    Teoria, if you go over 5.7V on the servo rail of Pixhawk, the latter will shutdown for protection, even if you use a power module. This is why as a precaution, you should connect in parallel a zener diode (5W recommended) with an avalanche trigger at 5.6V so as to trim any short voltage spikes above the limit.
    All is described in the wiki here : http://ardupilot.org/copter/docs/common-powering-the-pixhawk.html
    Good also to add a capacitor in parallel to the zener diode.
  • I undestand that you shoud use a zener diodo ONLY if you use the Pixhawk servo rail as a redundant power source. As "Andre K" wrote, I think I can use up to +5.7V but not usable as a reduntant power supply for the Pixhawk.
    If I put a zener diode into the servo rail (and my intention is not to use the backup power supply), I will damage my SBEC.
  • MR60
    Powering the Pixhawk — Copter documentation
  • It will not "cause" a reboot, but will not be used for redundancy. (which may cause reboot/shutdown if the powermodule is overloaded/fail)
    Pixhawk has triple power source, to keep redundant, you can feed it +5v from another source
