I built a DJI450 frame with the E305 motors and ESCs and Pixhawk FC and Taranis Plus RC. Started out with a 3s, 5,000 mah battery and had several good flights. Used Mission Planner autotune and everything seemed fine. Then switched to a 4s 5,000 mah battery. Had to lower the throttle midpoint to 325 as it was too twitchy otherwise. Started an autotune session. Went fine for about 10 min, at which point the quad shot straight up at what must have been full power and disappeared. I clicked out of autotune and tried to bring it back as it was in stabilize mode, but it was gone. Never saw it again. Building another one but am gunshy after what happened. Have added a Marco Polo tracker to the new one. Any thoughts/suggestions would be very welcome!
Rory, after try autotune fly a little, like one minute in hover stab, then alt hold and land, check your log for err or vibes, etc. If all looks correct, then try autotune; telemetry and Tower or MP are main tool, as others said, specially on a new setup, It save me more than one time ;)
I have had incredible success with pixhawk and the tarot 650 from day 0. But i hunted the forums for 3 months straight and learned everything i needed to know. Learned alot. I know Cala is a very active member you are getting some points from experience quad builders :)
Number 1 issue is vibration. KILL IT before it KILLS your drone. LEarn to fly in stabilize well then switch to alt hold then loiter then RTL. If all works well then do auto tune. Thats how i did it. My drone is now ready for mapping.
+2 to Tarot 650 ;)
@Cala, @Tony, thanks you guys.
ur welcome. this is what you need. dont let the price fool you. these have worked flawlessly for me. You have other options there too more expensive ones up to 50 bux that might be higher quality but the cheap ones are the ones i use. You can then spend more on a high dBi antenna. Antenna gain term is misleading because antennas do not amplify so there is no actually amplitude gain however some antennas are better designed to propagate that signal in a specific direction more than other directions. That is the gain of the antenna. I have yet to reach limits on distance with these radios. Good luck. Dont give up :)
http://www.aliexpress.com/item/3DRobotics-3DR-Radio-Telemetry-Kit-9...
Also what is this marco polo tracker is it this ?
http://www.amazon.ca/Marco-Polo-Monitoring-Tracking-Locating/produc...
Pet tracker ? $260 For a job that can be done much cheaper and easily with 20 dollar radios... that doesn't make much sense to me.
Thank's Tony; I try with polarized 900 hz from Hobby king and I hope I ruined a radio :(
