hi!
i have used pixhawk well with mission planner by last month.
recenlty i am trying to use Qgroundcontrol but it happened some error in pixhawk.
as you see in the attached video, when i connect the battery with pixhawk, the blue light is blinking
slowly and beeping sound happen periodically. also there is no light of B/E signal in the plate.
would you advise me how can i solve this problem?
i understood at first time, there was some problem of ESC Calibration, so i tried to do it
as i did in the past time(ref- https://www.youtube.com/watch?v=Hl-Q7RPOn18). but there was no change of the conditions.
i guessed "maybe there will be some special procedure in QGC!" and found ESC Calibrate button
in Qgroundcontrol. accordingly i pressed the button but the signal recommend to connect the battery.
so i connected battery instead of USB but when i press the ok button, procedure initiallized again to the first stage.
B/E signal lost and QGC's calibration error is related and same problem?
really appreciate your advice^^
rgds/elon
