  • You can see at the end how ThrOut increased, without voltage dropping, your current is not logged, but the end value jumps to 142  - even battery voltage just raised at the same time - indicating that the real current was not increasing at the time.
    I would bet you had a power problem, some wires or a BEC problem.  - And apparently - no redundant solution for powering Pixhawk.
