as of 1.0.96, the planner now used .net framework v4, make sure you have it installed.
Michael
Tags:
Permalink Reply by Andrew Radford on November 22, 2011 at 1:34am Is that going to play nice with Mono? I thought .Net 4.0 support was a bit iffy still....
Permalink Reply by Andrew Radford on November 22, 2011 at 1:58am Iron Python? Well, FWIW Iron Python can run on CLR2 and is supported by Mono, only problem is interop form C# => DLR is a bit harder due to the lack of 'dynamic'.
However looks like .Net 4.0 should work according to this page.
ive tested on mono 2.8 on windows, and no luck there.
Permalink Reply by Gareth Rens on November 22, 2011 at 11:58am Hey Michael. Iv updated to .net 4. But it still says APM planner has stopped working. It works perfectly on my desktop (x64 win7) but wont work on my laptop (x86 win7)
any suggestions?
G
ive tested on windows xp 32 bit, and cant find any issues.
Permalink Reply by Gareth Rens on November 24, 2011 at 10:40am After a bit of wrestling with 7. All is working 100%!
Thanks Michael!
G:)
Permalink Reply by Marc Paquette on November 25, 2011 at 8:12am Mine also stopped working since 1.0.97. I do have .net 4.0, Windows XP Pro SP3, I used the update feature from the Help page to update from 1.0.96 (which worked fine, besides the "Hello World" messages I would get in the console screen ;)
It seems the problem comes from IronPython, which I'm not familiar with. The exception dump goes like this:
Unhandled Exception: System.Reflection.TargetInvocationException: Failed to load language 'IronPython 2.6.1': Could not load file or assembly 'Microsoft.Scripting.ExtensionAttribute, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.Scripting.ExtensionAttribute, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.File name: 'Microsoft.Scripting.ExtensionAttribute, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' at System.ModuleHandle.ResolveType(Int32 typeToken, RuntimeTypeHandle* typeInstArgs, Int32 typeInstCount, RuntimeTypeHandle* methodInstArgs, Int32 methodInstCount) at System.ModuleHandle.ResolveTypeHandle(Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext) at System.Reflection.Module.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments) at System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, Module decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, RuntimeMethodHandle& ctor, Boolean& ctorHasParameters, Boolean& isVarArg) at System.Reflection.CustomAttribute.GetCustomAttributes(Module decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes) at System.Reflection.CustomAttribute.GetCustomAttributes(Assembly assembly, RuntimeType caType) at System.Reflection.Assembly.GetCustomAttributes(Type attributeType, Boolean inherit) at IronPython.Runtime.PythonContext.LoadBuiltins(Dictionary`2 builtinTable, Assembly assem) at IronPython.Runtime.PythonContext.CreateBuiltinTable() at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options)
WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
--- End of inner exception stack trace --- at Microsoft.Scripting.Runtime.LanguageConfiguration.LoadLanguageContext(ScriptDomainManager domainManager, Boolean& alreadyLoaded) at Microsoft.Scripting.Runtime.DlrConfiguration.LoadLanguageContext(ScriptDomainManager manager, LanguageConfiguration config) at Microsoft.Scripting.Runtime.DlrConfiguration.TryLoadLanguage(ScriptDomainManager manager, AssemblyQualifiedTypeName providerName, LanguageContext& language) at Microsoft.Scripting.Runtime.ScriptDomainManager.GetLanguageByTypeName(String providerAssemblyQualifiedTypeName) at Microsoft.Scripting.Hosting.ScriptRuntime.GetEngineByTypeName(String assemblyQualifiedTypeName) at IronPython.Hosting.Python.GetEngine(ScriptRuntime runtime) at IronPython.Hosting.Python.CreateEngine() at ArdupilotMega.MainV2..ctor() at ArdupilotMega.Program.Main()
Marc
Marc, your issue is that i missed a dll when i uploaded it. its now there, and tested on xp. so please try again, you may have to downgrade then upgrade again.
Permalink Reply by Marc Paquette on November 25, 2011 at 6:25pm I am happy to report that it's working fine now.
Thanks for your help, I really like this software, makes the whole experience so much easier
Marc
Permalink Reply by u4eake on November 25, 2011 at 12:06pm I also installed .net 4.0 on my windows xp. Still can't get mission planner to run. It always keeps saying it needs .net 4.0 to run. So I repair the install, install it again, all no avail, it keeps moaning that it needs .net 4.0
Stupid m$ crap :(
Permalink Reply by Toby Mills on November 25, 2011 at 12:58pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.47 members
51 members
24 members
1297 members
79 members
Powered by
