Please help - 3DR USB radio will upload firmware but won't enter command mode
I have a 3DR 915 MHz v1.1 USB interface radio that will not enter command mode using the 3DR radio config tool and does not respond to any commands. The unit was communicating whenfirst received, but stopped working when I tried adjusting some of the settings (I was trying to increase data rate at the expense of range for initial airframe characterisation testing)
I have been able to place it in bootloader mode by grounding the config pin at power on. I get a solid red led on the module and the config tool goes through the firmware upload process and finishes with a success message, however the unit still does not respond to any commands when it has exited bootloader mode.
I am running windows 7 64 bit on a toshiba laptop, and have no problems communicating with another 3DR radio (same model number)  from my other project. I have also tried using another PC running 32bit Vista, with the same result.
I'm now out of ideas.  Does anyone have any other ideas I can try before I return the unit?
Thanks,
Paul
Tags: I'm, now, of, out
Have you tried 3DR Radio Config Tool and "Reset to Defaults" button?
IMHO you've set different baudrate that one you're trying to connec at.
That doesn't work (It needs to enter command mode first before it can receive the AT&F reset command)
I have tried all of the available Baud rates.
Do you have connection between air and ground module?
If answer is "Yes", then connect air module to PC via USB-UART converter (FTDI cable), power ground module via USB an try to reach it via air module (as remote device).
No connection unfortunately.
I'm afraid that only RMA process is the answer...
