Here are some pictures of my setup: http://imgur.com/a/5QdDV
I'm new to the RC hobby and dirt poor so I've been building a DIY fpv system for my quad for about 50 bucks.
The issue I currently have is when the motors start spinning I get complete signal loss for roughly half a second every second or so. It doesn't seem completely regular so I don't think its a software or wiring problem. When the motors aren't spinning I get perfectly clear signal.
The transmitter only shares a power circuit with the microprocessor and the camera but not the motors. The transmitter also has a voltage regulator between it and everything else on the circuit. I've already tried swapping through channels and none of the other channels changed the problem. If I move the transmitter about a foot and a half away from the platform it works even with the motors spinning. Unfortunately this is quite unpractical.
My parts are tx5823-http://tinyurl.com/mczholm rc805-http://tinyurl.com/kjmvgqm camera-http://tinyurl.com/ozh6nnn Homemade rca cable antenna that reaches about 8 inches above the platform.
1000kv motors-http://tinyurl.com/o8pbmfo 20 amp ESCs-http://tinyurl.com/qxwms2j
Any ideas on how to fix this? I'm guessing I'm doing something wrong since I've seen fpv set ups on much smaller platforms.
You need sheilding on all you video cables and you may need sheilding right around your camera. A simple way to test this is to put the entire fpv transmitter and camera circuit in a metal box (don't short things to it), except the fov antenna, and thrn see if the motors still create interference.
I don't have a metal box handy, but would tinfoil work?
