were there any changes in loitering mode ?
- since last update i can't tell loitering is working...
.. always had to switch back to manual stabilize because quad went far in any direction.
thnaks for your help !
Tags:
Permalink Reply by James on January 26, 2012 at 7:55am i have noticed worse loitering performance as well with version 2.2 b2 on a jdrones hexa frame with 12x4.5 props.
as advised in the version 2.2 thread i have begun to experiment with the LOITER_P setting, but have not dedicated much time time to it at all. all i can say is that changing the value from 2.0 to 1.5 has perhaps slowed the rate of oscillation, but overall has not improved the stability. when the wind calms down a bit i will experiment some more.
james
Permalink Reply by Don Brooks on January 26, 2012 at 8:18am 2.2b2 is old, things are up to 2.2b4 now.
Reports from experienced people seem to indicate things are working very well, so if you have a problem it's probably mechanical, or your PID tuning that needs to be refined.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.15 members
50 members
247 members
106 members
1279 members
Powered by
