Do the accelerometer readings determine the position after the initial GPS read or does the copter rely solely on GPS readings for the loiter and auto modes?
Also, I am in the process of fine-tuning loiter mode, and it still makes wide circles about 5-10m around the point that it was initially switched into loiter. It has gotten better by lowering the Loiter Angular Rate P, but it still continues to oscillate. Are there any parameters that we can change to continue to improve the loiter accuracy.
Thanks!
Tags:
The single most effective thing you can do is upgrade your GPS to the new 3DR uBlox 6. It makes a remarkable difference in loiter and waypoint accuracy.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.47 members
51 members
132 members
691 members
87 members
Powered by
