Pre-Iris+ prop star washer
Hi Guys,
Been reading the forums for a while but can't find the answer so I hope you're collective intelligence can help. I have a pre-iris + at home and it threw a prop on a flight. I located the prop and the nut but cannot find the star washer that sat in the prop area. Is there a replacement just for the star/toothed washer that sat in the prop or do you guys have a better recommendation for props and setup? Thanks in advance.
  • I think I just use a 10X24 star washer from the hardware store.  Not an import piece.
    When you got your IRIS you should have gotten a plastic bag with a prop adapter kit in it.  You should have a star washer in there.
