Problem - APM 2.x wil not power up
Power problem – APM 2.x will not power up
07/14/16
Problem – APM 2.8 will not power up via power module but will power up normally with USB cable from PC in Mision Planner.
After I tried to add a buzzer to my APM (ordinary HobbyKing buzzer) via the ground and signal pins #6 on the long 16 pin rail (analog input pins) – now my APM will not power up except by USB and PC.
What did I brake?
Piezo Buzzer for KK2 KK2.1 & Naze32 Flight Control Boards (1pc)
http://www.hobbyking.com/hobbyking/store/__47014__Piezo_Buzzer_for_KK2_KK2_1_Naze32_Flight_Control_Boards_1pc_.html
I tried a spare power module from my Pixhawk – same problem.
I checked voltages on power module 6 leads – same in both power modules -
5.05, 5.05, 3.9, 4.5, 0, 0
Did I burn out internal fuse?
Help,
Vince
  • SOLVED – APM 2.x - no power
    I opened my APM control board and checked voltages after diode and found low value 1.49v
    So I jumpered the diode with a small yellow wire.
    Now powers up fine.
    So I guess I fried the diode by applying the buzzer on the Accessory rail.
    I will be more careful now.
    Many thanks to all the excellent documentation on the web for this control board.
    I have attached the information I found on the web and a photo of my repiar.
    Luck,
    Vince
    3702268446?profile=original
    check diode.doc
    https://storage.ning.com/topology/rest/1.0/file/get/3702268470?profile=original
  • Addendum:
    I measured voltages on APM with power module power and ESC power on output rail -
    Output rail 5.5v
    Input rail 1.1v
    Acessory rail 1.1v
    Thanks,
    Vince
