Hi, I'm in trouble with activating connection between a DX8 radiocommand and its receiver. After binding phase, no action is performed after any command sent. Is there any set up phase to perform before transmitting commands?
Please, give me any suggestion.
Thanks.
@Alessio,
Did the receiver led go from flashing to solid after the transmitter display indicated that it had completed the binding process?
Did you remember to remove the binding plug before you turned off the power to the receiver after the receiver was bound to the transmitter?
TCIII AVD
Yes,the receiver led becomes solid and I removed the binding plug before turning off the power to the receiver.
what can i do now?
thank you
Regards
Alessio Priore
