Good day,I bought a 3DRobotics X8+ Coaxial Octocopter but haven't been able to fly it because motor A (back bottom left) isn't working.I have tested the ESC and motor outside from the frame independently and it works perfectly, but when I put together the copter and do the motor test trough the Mission Planner it just gives a long beep and doesn't work. When I arm it, all the motors start spinning except from that one.It is labelled in the connection to the PCB as the No. 8.I have also tried using the ESC and motors from a different arm (using/changing other motor and ESC from the copter as the motor A) and still the same problem.What suggestion do you have? Is it a configuration problem in the Mission Planner or PX4? What should I try?Hoping for your help,Best regards,Juan Pablo G.
please contact customer support: help@3drobotics.com
