hi all,
I'm having problems with my arducopter.
Been calibrating esc's for a hundred times. must be doing something wrong. Who can help this noob?http://www.youtube.com/watch?v=_Xa5U8FhlrY
Tags: arducopter, noob, problem
did you calibrate your accelerometers?
please read the wiki BEFORE flying:
Permalink Reply by roger on May 6, 2011 at 9:24am Bart,
I have bias toward using the CLI (refer to wiki on how to go into cli mode) ... once in CLI, choose the menu that calibrate the minimum throttle level of transmitter ... might fix your problem ... by the way one of the menu also in CLI allows you to calibrate your accels ... good luck.
Permalink Reply by chris g on May 7, 2011 at 7:03pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
24 members
1283 members
180 members
4 members
Powered by
