Hello every body !
I am beginner in the field and I am French then I am sorry for the errors spelling or grammar to.
I would like to set up a prototype in Y6 for my internship and I decided to follow the steps on this site.
Unfortunately I have a problem when I want to do the calibration of the ESC
I think following  the configuration steps (- First time setup - ESC calibration - Setting corect prop management - Connecting camera)
Here's the problems:
I can't calibrate the ESC.
There are different symptoms:
 -When I do a calibration there is no beep.
 -In of other calibration, engine bursts in the disorder (ex: 2 7 1 8 4 3) but for engines 3 and 4,it's the  engine 8 turns.
 -In of other calibration, no engine wants to calibrate
 -Sometime engine will beep quickly and continued.
 -In of a calibration, the engine will be calibrate but when I accelerate, engine not working properly
I tried updating the software (mission planner).
Here's my questions:
 -Cable USB should remained online during the calibration?
 -Should be done a calibration of the remote control every time that I test a new calibration?
 -on your tutorial, you connect inputs (from RC)  and outputs (from ESC) of the APM card, is it  necessary to connect the two at the same time?
I have connected GPS, sonar and Xbee, be it the disconnected to the ESC calibration?
This is the equipment I use:
RC: Hobbyking HK60F 2.4 GHz 6Ch
Map: APM kit
software: Mission planner 1.1.42 (update 1.1.52)
I hope be understandably
Please answer me
Kind regards
Ben
Tags: ESC, calibration
You should try this method because I was not able to use authomatic calibration:
  1. With NO BATTERY CONNECTED, plug the three-wire plug of the ESC you want to calibrate into the throttle channel of your RC receiver.
  2. Turn on your transmitter and push the throttle stick to full up.
  3. Plug the ESC into the LiPo battery
  4. You will hear a musical note and then 2 beeps. After the two beeps drop the throttle to full down. You will then hear a number of beeps (3 beeps for 3 cell LiPo, 4 for 4 cell, etc) and then a single longer beep indicating the end points have been set and the ESC is calibrated and ready to fly. You may now disconnect your LiPo.
  5. Repeat for the other five ESCs.
  6. If it appears that the ESC's did not calibrate then the throttle channel on the transmitter might need to be reversed
Order is not important, but you need to do the above operation for all the 6 ESCs.
Also be sure you have NO trim and that your radio is configured for Airplane or Acro, not Helicopter.
Hope this helps,
Emile
Thank you Emile for responding and for clarification of the beeps.
I did what you said to calibrate the ESC and sometimes the ESC calibre and sometimes no (see symptoms).
Kind regards
Ben
Hello Emile,
I have two questions for you:
I followed what you said and ESC calibrates itself in disorder, let me explain:
- I tried to calibrate the ESC 1 and it did not work, ESC 2 it did not work, ESC 3 and it works, ESC 4, it did not work, 5 that the ESC did not work, ESC 7 it did not work, ESC Works 8, is this normal?
- When I calibrate an ESC (that works), there is a musical note, two beeps, I drop the joystick down, and there, there is 1 beep, 2 beeps, 1 beep, 2 beeps, the ESC does not calibrate. I vary the joystick up and down and after a few seconds the ESC is "calibrated" .. , Is this normal?
Excuse me for my expression
Ben
Ben what kind of ESCs do you have?
What you say is very strange.
Procedure should be same for every ESC unless there is a problem with your radio.
If you plug the radio in APM and use the planner what are the values you see in Configuration-->Radio Setup? The should be something like 1080 for the minimum and 1920 for the maximum.
Of course every radio has it' own limits, so they could differ.
Emile
Emile the error came from me, I have not translated your response correctly
The error was that I do not connected the wires of the engine on the receiver directly (entry 3, throttle)
This is why I'm sorry!
ESC are calibrated but in the tests, they can't to start, well I put the CLI mode fly, I use my remote control in mode 2.
When I plug my LiPo a melody sounds, followed by 4 beep followed by 1 beep, and more nothing.
Do you know this problem?
Ben
Have you ever calibrated an ESC before? One thing that got me at first was the fact that the ESC expected a minimum PWM from my radio. My radio outputted 1120 at low throttle, and the ESC wouldn't accept anything above about1080 before arming.
Jason
Thank you Jason for these details, not I never calibrate of before ESC, I followed the instructions on the site.
I could see what my remote control emits Monday.
I didn't understand (sorry I am beginner in English), the ESC does not accept the values below 1080? or above 1080?
Do I change remote control or I rule my remote control?
Ben
