Product Sales
I am selling some FPV equipment and wondered if you are interested in purchasing it or if you know of someone who might be interested.
I have a brand new Eagle Tree System. I purchased the equipment not realizing that in the future I would prefer using a video signal using spread technology. I have the ground station for tracking and some stabilization sensors and some other great features that can be tied together.
There are two receiver boards and two patch antennas. They plug directly into the Eagle Tree ground station via RCA cables. If one signal goes down, it can re-connect instantly to the other receiver.
The cable setup for the airplane is made to plug directly into everything aboard your aircraft. The Eagle Tree system powers everything by one battery. This is ideal because you can plug everything up including the engine. This is an extremely neat feature.
No matter what is connected to the system, it runs off of one battery. This makes the setup simpler because you can continue to add. I had some custom cables made to have the video signal go through the eagle tree system so I could view it on my monitor. This is possible because the video feed is imbedded in the data sent to the Eagle Tree. You can sit at your monitor and view all your data from there. You do not even need to use your laptop.
A friend gave me the idea for the setup. We used his equipment, tested out the aircraft and everything worked great. Flying at a nearby field, I began getting some ground planing. I realize that there was a loose connection in the RG-316 cable. The signal dropped and thought that I had lost the whole aircraft. Luckily the other receiver picked up (just saved $2,000).
I also have a video system; it has a 4.5-mile range. Basically the setup is one transmitter with 7dbi antenna and is 500Mw at 5.8GHz. Now you might be asking yourself, why would I want a 5.8GHz setup? Well, the video signal is fantastic and much higher. It does not interfere with other signals such as a 2.4GHz which many things run on. It uses two receiver boards and RG-316 cable extensions for the patch antennas to be placed on the pan/tilt station with servos. The pan/tilt servos are plugged directly into the eagle tree system for tracking. The camera is a clover camera, very compact and durable. The cable will power both the camera itself and the transmitter and covers the video transmission to the transmitter.
This is a great setup and at a good price. If you want more information on this setup please let me know. I have some great pictures. Please understand, this is some very rough information and does not cover everything. Please contact me if you have any questions at tad72597@gmail.com or send me a message. Thank you for your time and interest.
Timothy D.
Tags:
Permalink Reply by Timothy on September 13, 2012 at 7:20pm
Permalink Reply by Randy Brazeau on September 17, 2012 at 6:29am Hi Timothy,
Is this still for sale?
Randy
Permalink Reply by Timothy on September 17, 2012 at 4:28pm Yes it is. I apologize for the wait on the photos. If you still are interested I will gladly Give you a better quote than is normally requested. I have not had anyone want to purchase this setup for some reason and I think if people actually understood how good this setup was they would purchase it quickly. I apologize if I spoke to you before and just have not gotten back to you, but yes it is for sale. Let me know if there is something in particular you wish to purchase or if it is the whole entire thing. If you do purchase the full set I will give you a even larger discount. Please let me know if you want pictures of a certain product. Thank you for your interest.
Timothy D.
Permalink Reply by Randy Brazeau on September 17, 2012 at 7:03pm
Permalink Reply by Timothy on September 17, 2012 at 8:21pm FPV is a fantastic thing. It actually has allowed me to see my flaws in my flying and what I can do to continue getting better. The setup I am trying to sell is composed of three different sets The first set is the camera setup. The second is the diversity system setup. Basically what this is, is it imbeds a signal through your video signal and allows you to view info directly on your laptop. You can view your altitude temperature, how many G's your aircraft is pulling and much more. Including return to home features incase you loose signal. Now my setup is composed of two transmitters so if you do black out or in this case its called Ground Planing is where you loose reception between the aircraft and your video feed, this will decrease your chances of this happening. When you begin to get the effect you will see a very staticey effect on your television. Now this will happen when you bank your aircraft. This is a analog setup which most rc hobby enthusiasts use, but this is a much more quality driven piece of equipment. I guarantee if you search around you will find R/C equipment like this on many websites. The problem is these setups are in my opinion garbage. They say you get fantastic range and you ship it you get it start to use and crash there goes your aircraft. Now I'm not trying to tell you what to purchase but with my experience in the last ten years these are fantastic setups. I actually worked with this company on a project and have several UAV's and MAV's made by them. I have a digital system that uses spread technology and it goes 8km. This setup was a grand total of $9200.00. This analog system has as good of a picture or better than the digital. You just have to be in constant contact with your aircraft. So what I have seen my friends do is set the patch antennas on the pan/tilt system and use the tracking feature with the eagle tree system which is included and it will track the aircraft for you. You can do it also manually which is more difficult. You can place them on a tripod and move the tripod to the aircrafts position. Now if you are still interested please send me a friend request and we will go from there. I will upload some more documents later. Thank you for your time and consideration.
Timothy
Permalink Reply by Randy Brazeau on September 18, 2012 at 9:45am I sent the friend request.
Permalink Reply by Matthew Christenson on September 19, 2012 at 9:05am I just sent you an email with some questions!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.88 members
24 members
203 members
720 members
1355 members
Powered by
My name is Timothy and if you read what I posted above you will understand more about what I am talking about. I just wanted to say before I get started, thank you so much for taking the time to look at this or if your are just randomly viewing sales thank you also. If there is someone that would know that would be interested please let them know. I first wanted to say that I understand there are many scams and things of course that go around the internet and this equipment is brand new and this sale is 100% true. No ketches no gimmicks, nothing. I am truly dedicated to selling something that is of great value. The setup as I described above is brand new, It has been in the original packaging sitting in a water tight case for six months and the reason I need to sell this equipment is because I am going digital. Now I very carefully took out the equipment from the boxes to show you the equipment and what it looks like. There are some plugs and adapters I custom made so that they could connect to certain parts of the system with ease. The picture shows a complete setup from start to finish. You have everything you need for a very successful flight. The only thing you need is your own airplane. If you purchase this setup and there is an issue I will be more than happy to help you identify the problem and fix it. Now if you see the pictures below, there is a picture with the whole entire setup, a picture with just the camera setup and one with The Eagle Tree setup. If you are interested in purchasing a part of the setup that is also fine. This is very rough information, if you have any questions please message me. Thank you for your time.
Timothy
