I've been flying with a Spektrum DX5e until now, so I was only able to use the "gear" selection (5th channel) to switch between auto and manual.
My new DX7 allows me 2 more channels theoretically, but I'm stumped as to how to implement it for changing to other modes??
On the manual, the diagram indicates pin 8 (in, autopilot control) on the APM should connect to the receiver. This is fine for one mode. But now how can I get my receiver's extra channels to tell the APM to go to RTL, FBW etc?
On the "modes" setup it does not see me switching the additional channels on my transmitter (DX7), only the "gear" switch is picked up by the CLI. I've tried connecting another cable from pin 7 to my receiver, but no luck.
Please help!?
Tags:
Permalink Reply by Luke on August 17, 2011 at 9:38am You need to use a mix on your transmitter. Check the Wiki, Setting Flight Modes. The DX7 isn't yet listed but you may be able to use the same procedure as some of the other radios, a DX6i is listed for example.
Permalink Reply by Hein du Plessis on August 17, 2011 at 9:49am Thank you!
Permalink Reply by Hein du Plessis on August 17, 2011 at 10:33am Cant' seem to get this bit right:
GEAR --> GEAR ACT
Mine just says GEAR --> GEAR ON
Also, SW ELE D/R never shows in the options, just SW ON
I'll ask a dx7 expert tomorrow.
Permalink Reply by Luke on August 17, 2011 at 4:13pm If you have programmable mixing on your DX7 (I don't own any of these radios), you may wish to try the technique posted for the DX8 - it should be quite similar.
If you do figure it out, consider writing a blog post with instructions, so it can be added to the wiki for others with a DX7.
Permalink Reply by Hein du Plessis on August 17, 2011 at 10:51pm It's quite different to the DX8. I will definitely write an entry on how to program it. Not the easiest of user interfaces, the DX7.
Permalink Reply by Wessie on August 22, 2011 at 2:01am Hein
Will be glad to help with that if you dont manage.
I know the dx7 quite well, perhaps we can make a new Wiki Page
Permalink Reply by Hein du Plessis on August 22, 2011 at 2:17am Great thanks I think I'll pop in this afternoon.
Permalink Reply by Antonio on September 10, 2011 at 6:27am Hi Hein,
did you get configure the dx7 modes mixing channels??
If so could you help me??
This is how it worked for my DX7,
I use various switch combinations of the Flaps and the Gear switch:
Press Scroll Down + Select to access the programming mode
Go to Travel Adjust, click on Select till you reach FLAP, set FLAP to 65%-65% (with the increase/decrease button)
Leave gear on 100%- 100%
Go to mixing (by clicking Scroll button) , select mix 1
Select GER > Flap on
Set rate: to 19% and 31% (with the increase/decrease button)
Set SW to on
Leave Offset at 0
leave Trim: set to Inh.
connect APM to Ardupilot Mega Planner, go to setup and assign different flight modes to the switch combinations of your remote.
Permalink Reply by Hein du Plessis on September 10, 2011 at 7:40am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
