I've been flying with a Spektrum DX5e until now, so I was only able to use the "gear" selection (5th channel) to switch between auto and manual.
My new DX7 allows me 2 more channels theoretically, but I'm stumped as to how to implement it for changing to other modes??
On the manual, the diagram indicates pin 8 (in, autopilot control) on the APM should connect to the receiver. This is fine for one mode. But now how can I get my receiver's extra channels to tell the APM to go to RTL, FBW etc?
On the "modes" setup it does not see me switching the additional channels on my transmitter (DX7), only the "gear" switch is picked up by the CLI. I've tried connecting another cable from pin 7 to my receiver, but no luck.
Please help!?
Tags:
Permalink Reply by Antonio on September 10, 2011 at 8:26am With 4 modes i've to mix 2 channels too??
If you post it, perfect, in that way i can check what is the best choice for me..
Thanks again...
Permalink Reply by herve pellarin on April 22, 2012 at 1:05am this is the result you get, thx felix
Permalink Reply by Felix Meissner on September 10, 2011 at 9:35am yes,
using two 2 position switches (Gear and Aux) gives you 4 modes,
one 2 position (Gear or Aux) and one 3 position switch (Flaps) gives you 6 modes ...
Permalink Reply by Antonio on September 10, 2011 at 9:37am Ok, Felix much more clear now.... thanks...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
