Hello
I changed drone, I started a project with an Y6 I changed to a quad. My APM board was configured for Y6, when I changed drone, I download the firmware for the quad. I recalibrate my remote control, my motors. When I plug the lipo, the motors start to beep all the time ..
If I push the stick (yaw) to the right, the green LED is blocked. Yet I push the gas, the engine continues to beep, and does not accelerate ..
May be that the engines are not calibrated?
When I want to automatically calibrate the motors, I follow the wiki and when plugging the lipo, motors beeps all the time, and if I go down the throttle, nothing happens..
I hope to get help from someone because I can't solve this problem :(
Permalink Reply by nina eyes on April 17, 2012 at 7:10am When I plug my ESC DIRECTLY on the RC there is no problem!
if can't come CSE, where it just?
ps: sorry for my expression
Permalink Reply by Dave on April 17, 2012 at 6:59pm If the APM shows that it's arming, sounds like the firmware is running OK and your RC is talking to it correctly.
ESC's generally beep because they are not receiving a (correct) signal. I'd suggest you double-check the ESC connections to the APM are on the right pins and connectors up the right way.
Also, is your LiPo fully charged? Low voltage can also cause beeping.
If no luck with any of that, you could try reloading the firmware, making sure you erase the EEPROM first with the CLI command "setup" then "erase".
Permalink Reply by nina eyes on April 18, 2012 at 2:50am
Permalink Reply by Dave on April 18, 2012 at 5:33am Could you supply a bit more info about your quad including APM1 or 2, what ESC's, do you have a PDB, is the beeping regular and fast or slow ...
Have you tried a complete reload of the firmware? Sometimes it doesn't get it right.
Permalink Reply by nina eyes on April 18, 2012 at 12:54pm Dave
I will give you more information on the equipment used tomorrow. as soon as I get to my internship site I give you this information immediately.
Dave thank you very much for helping me
Permalink Reply by nina eyes on April 19, 2012 at 2:14am Dave,
Permalink Reply by nina eyes on April 19, 2012 at 3:13am And these are rapid beeps,
I did an erase on the eeprom and it y always beeps when I plug.
Permalink Reply by Dave on April 19, 2012 at 5:43am Does Mission Planner show the throttle at minimum setting? You may need to reverse your throttle.
Otherwise, you might have struck a known bug in the APM2 which they hope to fix shortly. A workaround is, after you plug in the LiPo and everything has started, try pressing the Reset button. You may need to do it a few times until the ESC's stop beeping.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
