Permalink Reply by Gerry Lichter on May 14, 2011 at 1:18am Speaking of mucking with the aerodynamics :P
If you're feeling adventurous, you may be able to get some additional lift at the same time by closing off the v tail with an additional airfoil/elevator.
http://en.wikipedia.org/wiki/T-tail
Similar approach as a box wing but for increasing rigidity of the tail instead.
I'm guessing you would have to adjust the center of gravity to compensate for the new aerodynamic center.
If that sounds stupid, you could probably KISS & brace the tips to each-other using control rod material without adding much drag or weight
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
51 members
11 members
182 members
1290 members
Powered by
