I read mixed views on using prop savers on multicopters.
Given the number of props i lost, even before having a good first flight, I felt I could use prop savers.
I would like to hear what everyone think about this.
Tags:
Permalink Reply by Greg Fletcher on April 12, 2012 at 10:12pm I wouldn't use them on a copter or you might loose a perfectly good prop. The prop will survive the fall, but the rest of the copter?
Interesting. by "you might loose a perfectly good prop" do you mean that prop could go loose/escape during a flight?
Permalink Reply by Greg Fletcher on April 12, 2012 at 10:31pm Yea that's exactly what I mean. I was bench testing a small motor with the built in prop saver and it had a resonant vibration and when I gave it full throttle the thing flew off and all most hit my face. Something hit my ear, I think it was the little o-ring that held on the prop. I finally found it and it didn't break, it just came off from vibration and thrust. I wouldn't trust one.
Not prop savers, just look at all the expensive commercial units, not a prop saver to be seen.
They introduce vibration and make the entire experience more dodgy.
Hoping to put a camera on the quad. More vibrations would be a nightmare.
Permalink Reply by Christopher Cooper on April 13, 2012 at 6:48am Started out bolting my props on and broke a ridiculous number. I've lost very few since switching to prop savers. My quad flies fine with them and I've yet to lose a prop in flight. Check the o-rings regularly and swap out any dodgy looking ones.
Which prop savers you are using? hobbyking?
Permalink Reply by Christopher Cooper on April 13, 2012 at 6:56am Yep, just the ones that come with the motors I use:
http://www.hobbyking.com/hobbyking/store/__4701__hacker_Style_Brush...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
