I am fascinated with the autonomous FPV flight aspect of a quad. The closest I can get without spending a $1500+ on a DJM WK-M is the APM 2.0 which I understand has full GPS autopilot (even autolanding) capabilities. While, I understand the ArduCopter 2 can come equipped with it, I much prefer the MultiiWiiCopter Scarab X frame (purely from the a looks perspective) and also the the full Arial Photography package kit. My question is, can I easily replace the PARIS 6 controller with a APM 2.0 (still on backorder). Does it require any "skills" to do so or is plug and play
Tags:
Permalink Reply by isojed on February 19, 2012 at 5:12am You could easily swap out the Paris controller for the APM2 as all flight controllers have a number of receiver inputs, motors outputs. It should be plug-and-play, flight however is a whole different thing. Like all flight controllers, you need to configure it.
The power distribution i.e. battery, esc, servo's and flight controller needs planning. The most important one is the flight controller, do you power it from one of the ESC (output rail +5V) or from the input +5V rail e.g. secondary battery with UBEC.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
133 members
1298 members
249 members
106 members
Powered by
