Hi all,
After a huge delay with Arducopter things I have designed and assembled new crazy hexa frame using PVC water supply parts from local shop
I finished few days ago and make a first little flight in my patio, looking no too stable, but suppose to be small props issue (currently I am using 10” APC), hope after switch to 12 will be more stable.
Final weight is 2.3kg (with 4000mAh lipo) sounds too much, but PVC is a bit heavy.
Here is some picture
http://www.vepetrov.com/photo/displa...859&fullsize=1
http://www.vepetrov.com/photo/displa...862&fullsize=1
http://www.vepetrov.com/photo/displa...872&fullsize=1
http://www.vepetrov.com/photo/displa...877&fullsize=1
http://www.vepetrov.com/photo/displa...878&fullsize=1
Other pictures you may see in my gallery, just not to bother not interested peoples…
http://www.vepetrov.com/photo/thumbnails.php?album=26
I also made a video of the flight.
10”APC definitely too small for this weight and motors (hover only at 95-100% of throttle)
http://www.youtube.com/watch?v=wLVOMbzWp60
Regards
Victor
Tags:
Permalink Reply by Gotleg on December 30, 2011 at 1:15am Nice job !
Do you have an idea of the weight of the empty frame ?
Permalink Reply by Sanbernar on December 30, 2011 at 10:32am Thanks :)
as far as I remember pvc parts weight was about 900-1000gr (without screws and glue)
Permalink Reply by bmarshall5253 on December 30, 2011 at 1:39am Great use of PVC
Have you considered lightening holes in the top and bottom of pvc arms?
Hole in the middle of the aluminum motor plates both to reduce weight and provide airflow through motors (okay I see in the part photos you do have a hole).
That central hub looks like it is built like a tank, plenty strong.
What glue did you use?
Permalink Reply by Sanbernar on December 30, 2011 at 11:34am Thanks :)
yep, I was considering to make holes but it's require some strength tests, pvc is quite "soft" and also it's could add some vibrations.
To glue parts I used epoxy for PVC but before using it I also add some roughness
This is the glue I used
http://www.homedepot.com/h_d1/N-5yc1v/R-100371824/h_d2/ProductDispl...
720 members
203 members
1355 members
207 members
Powered by
