Hi all,
I need an airspeed sensor for my PX4. According to the documentation, this is an analogue sensor (same as APM), however it needs a funny DF13-3S-1.25C connector. Not the usual PCB header APM uses.
Does anyone know where to get either:
  • Airspeed sensor and cable designed for PX4
  • DF13-3S-1.25C connector on wire (so I can solder on a 3pin header and use and APM sensor)
Thanks in advance!
Si
Anyone got any ideas, please?
Solution found, thanks to Martin Poller:
You need the plastic plug,here.
You also need three wires with the crimped socket on to go into the plug. These come in redwhite, and black, all pre-crimped.
