Quadcopter reccomendation
Please can anyone suggest a quadcopter which would be as close as possible to the specs below:
List Specifications Requirement
AIRCRAFT Max Ascent Speed 5 m/s
Max Speed 16 m/s (ATTI mode, no wind)
Max Service Ceiling Above Sea Level 6000 m
Max Flight Time Approximately 25 minutes
Operating Temperature 0°C to 40°C
Navigation System Built-in GPS
Gimbal Controllable Range Pitch -90° to +30°
Angular Vibration Range ±0.02°
Camera "Lens
" FOV (Field Of View) 94° 20 mm (35 mm format equivalent) f/2.8
Image Max Size 4000 x 3000
Video Recording Modes "FHD: 1920x1080p 24/25/30
HD: 1280x720p 24/25/30/48/50/60
Supported File Formats "Micro SD Card: FAT32/exFAT
Photo: JPEG, DNG
Video: MP4, MOV (MPEG-4 AVC)"
Intelligent Flight Battery Capacity 4480 mAh
Voltage "15.2 V
Battery Type "LiPo 4S
Operating Temperature "minus 10 to 40°C
"Max Charging Power
" 100 W
Remote Controller Operating Frequency "5.725 GHz – 5.825 GHz, 922.7 MHz – 927.7 MHz (Japan)
Max Transmission Distance "FCC: 1000 m; CE: 500 m (outdoors and unobstructed, aircraft's altitude at 400 feet (120 m))
Operating Temperature "minus 10°C to 40°C
Battery "2600 mAh LiPo 18650
Charging Port "Micro USB
Charger Voltage 17.4 V
Rated Power 57 W
Wi-Fi Video Link Operating Frequency 2.400 GHz – 2.483 GHz
"Max Transmission Distance
" FCC: 1000 m; CE: 500 m
Power Spectral Density 5.69mW/MHz
App / Live View Software Use cellphone or tablet
Live View Quality 720P @ 30fps (depending on conditions and mobile device)
Required Operating Systems "iOS 8.0 or later
Android 4.1.2 or later"
Camera bag 48sm*38sm*23sm
