Hi Guys,
I need to have wireless connection to Arducopter to receive and transmit commands and video with WI-Fi router. I have an OpenWRT compatible router and need to run OSLR (Optimized Link state routing protocol) on arducopter.
1) Is this possible, if so how can I achieve this?
2) What should I install/ hack on the arduino (ATMega board)?
Thanks for the upcoming answers;)
  • look at http://www.openipcam.com the wins cam is able to run open wart as well running a web server porting video
    Open IP Camera Forum - Index
    To gain a wifi link you could use this https://www.sparkfun.com/products/10822 reading the data-sheet it does not support OLSR.
    I pretty sure the APM is not capable of running a routing protocol as well as the ArduPilot code. If you where to support t you would need an off-board device that can do the processing fro you and translate that to serial to the APM
