Hey guys, I didn't know which threat to throw this in because it deals with, fpv, controls, aerials, wifi so yea. Ok so Im planning on building a Fixed wing UAV for my year 12 HSC DAT project.
Because I live in australia and rf bands are usually restricted(Like the bands for dragon link etc), I decided that I should use a ptp 2.4ghz ubiquti setup. Latency shouldnt be a large problem for me as it would a slow flying phototaking plane, so if it a few hundred ms out it shouldnt be a problem except for landing but I should be able to sort somthing out. Now im planning on sending video and controls through a ubiquti wifi connection which will be comming from a raspberry pi to a field laptop. I have already been able to send my controls to and from the raspberry pi using ethernet, so everthing works so far. Now my question is that I was planning on using the 2.4ghz rocket m2 and a nano station. But I found another project which uses the rocket m5 and a nano station(http://diydrones.com/profiles/blogs/how-to-build-a-high-definition-fpv-uav-using-a-rasperry-pi-with?commentId=705844%3AComment%3A1792912&xg_source=msg_com_blogpost) It got me wondering should I use 5ghz because of the smaller antenna, but I dont really need such a high data transfer that the 5ghz offers. Also shouldnt 2.4ghz give me a longer range? Also does anyone know some relativly small omni circular polarised 2.4ghz antennas that I could buy? Also should I use a bullet m2 over the rocket m2, its smaller and lighter but the only omni antennas i can find for it are 1m long and cost $200?
Sorry for the ammount of questions and im still learning so please dont be to hard on me. Thanks
  • use 5ghz better perpetration of building trees give you longer range. 2.4ghz antenna are much larger than 5.8ghz HK mas still have some but expensive .
