Radio Pitch Reversal
In simple and stabilize mode (have not tried anything else yet) all tests are good - quad resists moving it from horizontal and left and right stick, yaw input and vertical input from radio all behave like they should.
However pitch towards me tilts the quad away, pitch away tilts the quad towards me.
Tried reversing channel 2 on radio but that had unexpected results.
What is the solution? Please!
    Run the radio test. move the pitch, roll sticks to the lower right. Do you see CH1:4500, CH2:4500? If one is -4500, play with your radio reverse until its right.
    Note: You can have a slightly lower values and it will work fine!
    Jason
