Hi guys, I have a problem reading my sensor, the altitude is starting to increase a lot!
I'm using the Analog output of the Sonar that comes builtin with the PX4FLOW and I'm connecting to the PIXHAWK in the analog input, doing this:
http://ardupilot.org/copter/docs/common-rangefinder-maxbotix-analog.html
3691306399?profile=original
The measure of the sonar works well in the analog input, I have a 1 V/m scale and is very accurate,
****but the altitude starts to increase when the drone is on*****
3691306521?profile=original
.....and after a while..... the top is 40,000 m
3691306538?profile=original
 I can't figure out what is the problem, this are my parameters for the Range Finder 3691306545?profile=original
If I change EKF_ALT_SOURCE = 0 ( use baro) the Altimeter works well but I can't use the RangeFinder with this option enabled
3691306608?profile=original
Any ideas ?
