Ealier I was able to see the green lines on the Transmitter calibration tab moving.  After fidling wih the settings they dont move. I re-installed the firmware and got the GPS, and all the raw data to show. Now, for some reason I cant calibrate or see any input from the RC to show.
Before, the PPM led would blink, it would blink faster as I would push the throttle up..
Any clue on this problem??
maybe your 1000mAh battery is too low to power your RC receiver?
Mhhh I have just plugged a fresh battery and nothing.. before, the PPM led would respond ( blink faster) as i would push the throttle up!!!
Would this problem have to do with the firmware or settings?? do i need to reload any software to the APM??
are you sure everything is connected, and tx/rx are bound?
Still the same..where gan i find info on the buttons that are on the boards???  the PPM light used to flash.. and I could get the RX/TX to work.. now the PPM is solid.. what can I do?
Are you powering the board via an ESC? What radio are you using?
All detail on buttons and LEDs is in the manual.
Hi Chris whats up??? good seeing you here..
I have a dx5 ( will upgrate to a jr 9ch soon)  power comes from ESC... I calibrated all ESC and only one motor responds OK to throttle...
the other motor never stops spinning and when I lift the right stick.. it slows down... the other motors (ESC) beep...  the PPM light is allways on?? and I cant get the calibration APMsetup to work...
PLEASE HELP!?!?!
TX and RX are bound because if I turn off and on the transmitter, I se the led in the rx turn on and off.
This will sound like I'm crazy - but try to upload firmware via Arduino. Worked for me when I had such trouble.
Cool.. can you post links to the firmware download page.. and the Tool to upload the FW....?? thanx
Hello.. I just compiled the lates Adrducopter in Arduino 023 and it uploaded fie, then in mission planner I uploaded quad firmware and then ran the setup, did a reset and when i get to the Radio setup I cant see anything moving... same for the CLI.. i binded a new RX and still the same.. im using a lipo to power up.. I get all raw data fine.  thank you
Try to plug servo directly to your RX and see if it moves... Also check whether your TX in PPM mode, not PCM!
