APM 2.24 seems a bit big for atmega1280.
When compiling for arduino mega 2560, It gives this memory report:
Binary sketch size: 131036 bytes (of a 258048 byte maximum)
Any pointers to reducing the code size so it will compile for atmega1280?
Tags: apm, atmega1280, footprint, memory
explicitly define the type of GPS controller you have, and it'll disable to autodetection code, which in turn disables all the code for all the GPS module/s that are not being used.
Sweet, just under the wire!
Binary sketch size: 126844 bytes (of a 126976 byte maximum)
Please sir , can you upload a guideline or a photo with info aboute how to  "define the type of GPS controller you have, and it'll disable to autodetection code"
Thank You
Nikos
Add this to APM_Config.h:
// GPS is auto-selected
#define GPS_PROTOCOL         GPS_PROTOCOL_UBLOX
Better to read this,
http://www.diydrones.com/profiles/blogs/getting-the-most-out-of-your
He might have another GPS than UBLOX...
Another option to reduce the memory footprint is to turn off the DataFlash logging.
