I am an amateur and I am onto making an android controlled UAV, using APM and PhoneDrone android board. I got a few doubts.
1. Is there an application interface currently available to solely control, collect data and images from the UAV using my android tablet, without the need for a computer?
2. Is the board and the code compatible with android 3.2 Honeycomb?
3. My device does not have a standard microUSB port, but it has a Samsung proprietary port. but I think interfacing wont be a problem.
Thanking you in advance...
Tags: APM, Android, PhoneDrone
Permalink Reply by Edward Jose on October 18, 2011 at 2:38am Like, just to clarify, I want to eliminate the use of a standard Windows/Mac/Linux system totally for operating the drone.
The Android GCS is called Copter GCS and you can read about it here.
Permalink Reply by deadfalkon on February 22, 2012 at 2:41pm How is your project going? Have you been able to solve your problems? I´ve started a google group today if you want to join the conversation: https://groups.google.com/forum/?hl=de&fromgroups#!forum/phone-drone-adk
Permalink Reply by John on February 29, 2012 at 6:15pm Any progress since your last post Edward? I am trying to do a similar thing but have several questions with regards to the PhoneDrone. Do you know if I can connect the PhoneDrone to the telemetry?
Thanks,
John
Permalink Reply by OG on February 29, 2012 at 6:50pm All you need is android 3.0 device or garter 4.0 is out now. A good China device will run you about $200 no GPS. To answer your last question you would plug your phones USB charger cable into the full size USB port in the APM. I was using Dell streak for this but I broke the screen. In regards to your first question Android developers have used the ADK to control camera & snap shots from DSLR & the board will run this code but you can not use the board as an APM & camera controller at the same time.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
184 members
11 members
182 members
1290 members
Powered by
