This is sold at the DIYdrones store. I bought one - and I can fine no pictures manuals YouTube videos - zip, 0, 0.
Remzibi OSD 3DR- references can't be found.
Remzibi has not posted on RCuniverse, or DIYdrones for ~ six months.
Does anyone know why I can't find info on this OSD. Its a purple board with two button switches.
Every reference refers to early versions (red).
Please - bernienepper
Pin "T2" is the RPM-Hz input.
The max frequency is about 34Khz and for a two bladed prop you might have to enter .5 into the gain value.
Let me know if the Eagle Tree sensor works, I tested with a signal generator.
Sorry for the late reply it's been busy for me lately.
Keith
Hi there.
Manual is here: http://stuff.storediydrones.com/Remzibi%20Tutorial.pdf
Do not update Firmware until further details are released, i updated mine and it doen not work anymore :(
Cheers!
Unfortunately I read this post later.
This morning I received my Remzibi 3DR, and tried to update it.
Indeed it has stopped working and the blue LED is not lit.
Someone may be taking a hand? . Would be very grateful, I'm standing with a plate paperweights called remzibi
Thanks for the manual. I did find it after I was able to make my setup running. Question: In manual it says the Mediatek GPS cumes with firmware for APM and will not work as default with Remzibi and need to change the GPS firmware. I did NOT do that upgrade, I did simple plug the GPS to Remzibi and it worked normal. I see the Lat/Lon coordinated, 10 satellites, blue fix led. Should I really do a GPS firmware upgrade since GPS seems to work fine with default firmware?
And last question: couple of time GPS altitude displays negatives values. I do resetting home, it put to 0zero altitude, but later seconds show negatives. Not always. And couple of times the altitude does not vary, even the model altitude change visible. All the other values (Lat/Lon/Speed) looks OK. Any clue?
Hi there,
Upgrade the GPS to the recommended firmware and check if that solves it. Normally it should be fine. Dont forget to switch rx / tx on the FTDI cable when you connect to the GPS (use some jumper wires).
Cheers!
@bernienepper
Were you able to get the Remzibi OSD to work with the APM2.
Reading this forum has not giving me any clue on how to achieve this connection.
